Opteron 165 temps
17 Oct 2002
Leeds
Hi there
Is 50c a safe temp for an Opteron 165 at 2.9GHZ on default voltage 1.3v? I'm new to these chips compared to single core. Running Orthos now both cores 50c using Core Temp 0.95 on the 'Large in Place FFTs' test. I think 65c is the rated max temp for these cores. I only have an Tthermaltake X90C and 92mm fan pushing 32CFM.
Thanks
Michael
P.S. Maybe this should be in the Overclocking section if so please move.
I've had two 165's and a 170. Temps up to 80 ish didnit cause any problems.
Better to aim for no more than mid 60's if possible
AD
