System is: Seasonic 600W, DFI Lanparty UT NF4 SLI-DR Expert, Opteron 170, TwinMOS 3200 RAM.
Goes straight in at 250Mhz, stock volts and seems stable (Can do rounds of 32M pi no problems), everything on default apart from the RAM which I've currently got on a divider of 2/3 (making 166Mhz). I've noticed the HT bus is still on x5, so this means it's running at 1.25Ghz, but hey, it's stable, so why change it?
Now,
At 256Mhz, it starts producing failures in the BIOS's built in MemTest86 after about 15-20 minutes. I've not attempted to boot Windows at this frequency as I'm thinking it'll most likely only trash the registry or something daft anyway.
I've tried reducing the HT multiplier from 5 to 3 and changed the voltage slowly upwards all the way upto 1.5V (I don't want to go above default+15%), but it doesn't seem to make any difference whatsoever?
Is there something I'm missing here? Normally I'd expect a bit of extra voltage to at least stabilise a slight extra overclock, but it seems that the extra vcore makes no difference whatsoever.
I've not got the stepping as I was too eager to stick the HSF on :-/
Any ideas to get this chip to 2.6 ?
Now,
