Opteron 170 Or Athlon 64 X2 4400
11 Oct 2005
Im Planning to buy either of these, id assume the opty is better overlocker, but which do you think would be best to buy between the two.
If your confident your system will give a usable and stable overclock the optie otherwise take it easy with the 4400 at stock.
Read every other thread about X4400s or Opti 170s. Pretty much every time people go for Optys. Dont get it if you are going to put it onto phase cooling. If your not, GET THE OPTY! I LOVE MINE!!!
