Hi
Just ordered an Opteron 180 retail and was wondering if they come with HS/fan? I had sort of assumed that all the retail packs did (like my Athlon 4000+) but not sure from looking at the description spec. whether it does now!
If it doesn't, can someone recommend me a decent quality HS/fan suitable for the 180 (NB. probably not looking to overclock it... well not by much).
Got to also admit that though I built my current PC, I've never removed an existing CPU before. I've looked at the video on AMD's site and it doesn't look to difficult. The only slight worry is... is removing the old HeatSink really as easy as it looks? IE. just wiggle it from side-to-side and then ease it off. Or can I just remove the CPU with the HeatSink still attached?
Thanks...
Thanks...
