El Jimben said:My 170 does 2.8GHz on stock volts, 3GHz at 1.5ish. Stepping is CCBBE 0615EPMW
I think it was pushing 60c but then I'm only using an AF64 Pro, I'm gonna swap the stock fan and replace it with a 120mm one and see if I can get it higher, I reckon I might be able to!jigger said:What sort of temps are you getting a 3ghz ? and what cooling are you using
Cheers
Crowze said:3GHz stock volts. I've had it up to 3.2 and I'm sure it could do more, but either my memory or motherboard doesn't like it even at a lowered multiplier, and orthos throws a fit. Likewise with a Freezer 64 Pro, although the stock cooler was almost as good.
I've no idea, to be honest I just bought it on a whim, stuck it in and clocked it . I'll find out (and find out how to find out) soon and let you know. Cooling... possibly, but there's certainly enough airflow around it as it's in a fully decked out CM Stacker. A high-end cooler might help, but spending £30 just to get another 100-200MHz out of it isn't worth it in my book.jigger said:What stepping is that one mate, sound's a very nice chip, mybe needs just a little more cooling.
Cheers
El Jimben said:I know it's a 180 and not a 185 but check out biohead's overclock
http://www.xtremesystems.org/forums/showthread.php?t=96900&page=146
The dual core ones all use the Toledo core, not sure about the single core variants though.jigger said:That is one fast chip m8. are all the opterons the same core ? some very close speeds regardless of what of opteron. the higher multi only seem's to give a slight edge.
Cheers
jigger
El Jimben said:The dual core ones all use the Toledo core, not sure about the single core variants though.
CPUZ and Coretemp say Toledo but I have seen it called Denmark elsewhere. I remembered that the single core Optys use the Venus coreJustintime said:Theres Denmark as well, can't remember any others off hand.
