Opteron mobo with agp?
30 Dec 2005
Hi all
can anyone recommend me a decent mATX 939 mobo with agp slot?
I dont mind a little overclocking too :D But will most likely change the XP-120 to something that doesnt get in the way of the AGP slot!
It will be going in a Thermaltake Bach case.
any advice would be great, thanks.
actually yes it does, but with a normal size board it gets cramped quite abit.
Will have to search for the A8V-MX as not many etailors selling them. Thank for the info mate.
Not sure about the specifics, but be careful putting that CPU cooler into that case.
The XP-120 is both a big cooler and a tall cooler (especially with a fan on top).
If you're planning on using it with that case, it might be worth finding out if the case is tall enough.
nice find p4radox :)
board looks ok to
the price seems good for what it can do as well.
hi hartgeh3 no the 1 at the bottom of that page is a standard ATX board, ocuk don't sell the ASRock 939A8X-M.
but if you google ASRock 939A8X-M you will find other retails in the uk selling it
please don't add any retailer links to this post they will only be removed
