These are true words indeed!Mrchu_ said:personally if the 3700s are good now, id buy now! and worry about food, toilet paper(ride bike to work) untill next month.you never know it might just almost pay for itself
Or use a divider to keep the RAM at stock speed while overclocking the CPU, you don't need fast RAM to overclock a A64Jestergt said:words of wisdom! Thanks for all you help chaps. My 3700SD Retail is on its way. Cannot afford ram until the 3rd of march. Will just run the cpu at stock speeds for now.
You don't need to be smart to overclock, you just need more experienceJestergt said:damn i wish i was as smart as you guys, Thanks again.
pegasus1 said:The GEil Value is good stuff and because you can run a divider it doesnt need to run fast, my Geil Value is rock stable at HHT of 235 (but i run it on a 333 divider with my 3700SD anyway) and for the price you get 2 Gig rather than 1 gig of very fast stuff. Some current any many upcomming games will run faster with 2 Gig mem.
that is as long as the memory is *happy* to run on a divider, sometimes it doesn't work, depends on ram (or maybe the mem controller onboard). I have some Ballistix PC3200 that can run from 200MHz-295MHz 3-3-3-8 but for some reason most of the dividers don't work with my ASUS/Opteron. . .man_from_uncle said:And you are correct that running ram on a divider is no longer a problem with these cpus.
