Agent WD40 said:Same here mate but I needed a 0.5v bump to get it there.
- Speed - 2800RPMAgent WD40 said:i'm using some heavy air cooling. TT Big Typhoon with a YS-Tec 120mm fan which is massive (the 32mm deep one).
Big.Wayne said:I have mine on a fan controller, normally turned down low and still shifts good amount of air, then when i need to test for possible heat issues it gets cranked up!!
If your into *Air-Cooling* then a good fan controller is a must!Agent WD40 said:Hmm, i'm getting more and more interested by one of these "Fan Controler" thingies.
How do they work?
Will they control a 4pin molex connecter?
Main benefits of having them?
