optibay install, boot drive issue
7 Aug 2004
As title, I moved my SSD from my macbooks default drive holder to an optibay, now the PC only boots if I hold the option key to bring up bootable area options, if i dont touch it it sits there for ages and has a '?' symbol, any way of changing a setting in OSX to tell it the boot area is always where the cd drive used to be ?
You can boot just fine from the optibay - the solution is above, the startup disk preference.
Speed from the optibay is exactly the same as primary hard drive bay.
