Bit of an issue with a new build
The ODD (dvd-rw) keeps making noise like the noise it would make at boot up/when initially reading some thing - like a high pitched buzz / churning, not just a flicking noise. (followed by the green activity light).
It does this what seems like completley at random, some times twice within 10 seconds, other times a minute or so goes by. The drive is empty whilst this is happening.
note: the drive is working fine otherwise, have had disks in it, installing etc. It only seems to start acting this way after windows has booted up, as if something is trying to access it or is forcing that kind of activity.
It is a fresh install of windows 7 64 bit on a new build.
Asus P8z77-v mobo, have had the drive in 2 different sata ports.
SSD and HDD are working fine.
All that had been installed is the mobo drivers, gfx drivers etc
Windows updates ad thats it.
Disabling the drive in the device manager stops the issue, but that's not really fixing it.
Any thoughts?
Help appreciated.
Any thoughts?
Help appreciated.
