3 Sep 2013 at 08:01 #1 deadpresidents4 deadpresidents4 Associate Joined 13 Aug 2012 Posts 258 I have an old IDE optical drive, how would I change the data output to SATA?
3 Sep 2013 at 08:06 #2 almoststew1990 almoststew1990 Soldato Joined 12 May 2011 Posts 6,335 Location Southampton You need a sata optical drive to do that. Ide and Sara are not compatible with each other. Also note that your optical drive might need a ide80 cable not 40. 80 has 80 thin lines whereas 40 has 40slightly thicker lines. On the plus side, you only need a bog standard Molex 4pin power connector!
3 Sep 2013 at 08:25 #3 HeX HeX Soldato Joined 20 Jun 2004 Posts 12,024 Location Huddersfield, UK Be easier just to buy a £10 SATA DVD-RW...
3 Sep 2013 at 08:34 #4 d_brennen d_brennen Soldato Joined 30 Jan 2009 Posts 17,559 Location Aquilonem Londinensi HeX said: Be easier just to buy a £10 SATA DVD-RW... Click to expand... Nah, spend £15 on an adaptor
3 Sep 2013 at 13:10 #5 bledd bledd Don Joined 21 Oct 2002 Posts 46,882 Location Parts Unknown Just get a USB DVD drive, far handier and only a couple of quid more than a SATA drive. When do you ever really need an internal drive now.. (Unless it's a media PC)
