optical on asus x99 deluxe
1 Aug 2012
hi guys cant get my head around it i can get the 5.1 setup to work with onboard sound but i dont get any settings like speaker configuration or anything. but if i plug in the headphones i get all the option so how can i get this with optical cable.
So are you trying to get 5.1 to work over SPDIF instead of analog outputs?
Likely reason is that unless sound card supports AC3/DD or DTS encoding (or source material is already in it) it can only output two channel stereo PCM over SPDIF.
Also selecting SPDIF as output in Windows Sound Playback settings bypasses sound card's software
Though buggy so and so software can't be excluded as Asus basically uses marketroids as designers.
Don't think you will get speaker options for optical. Normally it'd just chuck the signal out for a 5.1 amp to deal with.
