Trying to work out the best use of my existing case fans in this case before building.
I have
4x Noctua NF-12 120MM
3x Arctic P14 140MM
2x BeQuiet Pure Wings 2 140MM
I've had a best guess at proportions here:
I'll remove a portion of the bottom panel so the lower 140mm isn't wasted. My main concern is on the top-right exhaust diverting air away from the CPU Cooler, am I over thinking that?
I note a fan can also be mounted at the bottom if all the PSU shroud is removed, but is that worth doing?
I have
3x Arctic P14 140MM
