optimal coulor & brightness settings for belinea 22" tft
23 Feb 2004
Greenside/Tyne & wear
Well on advice I got the belinea 22" ws tft, thing is I need to get a happy medium for colour & brightness & its doing my head in especially on cs, its either too bright or too dark.... unless the panel is buggered. need peeps colour, contrast & brightness settings to try.
Thanx in advamnve Kev!
nah still odd, colours dont seem right at all sadly & the red & green is really dull. monitor does not even compare to the 19" hanns-g sitting next to it :(
tipsy said:
still need help
Kev!
Try this........with 85 brightness and 50 Contrast on the monitors menu........set these settings (Digital vibrance is most important!)
Nate
I use 33 for brightness, 35 for contrast, 9300k colour and have the settings tweaked a bit using the Nvidia display optimisation wizard (basically my gamma is turned down a bit). Also got 11% digital vibrance.
I'd highly recommend running it as I have the same monitor and found this makes my icons etc look a lot better.
