Optimize settings asrock z690 bclk + cpu vcore offset
2 Jan 2014
I have an asrock z690 pg riptide i wanna optimize
cpu 14100f is not running bus speed (bclk) at 100 + i don't see any cpu core/cache voltage (offset) if i set it to 100 to what i think is cpu voltage offset, it raises cpu voltage by 100 mv
Does any know where if i can set bclk, i don't have the settings (i once had a mb that also didn't run bus speed at 100, setting it to 100 it was much closer to 100 like 99.98-100), i have heard intel limits bclk on a 14 gen to 103 mhz so it should be possible to get it running closer to 100 as long as i have that option in my bios
img_20220324_214717-jpg.2553193
Core voltage offset i don't have but i can do it with Asrock Phantom Gaming Tuning.
Isn't there any way i can do it in the bios ?
