- 14 Nov 2006
no brainer......new case!
coolermaster cm-690 ii,great case ,good airflow but a little noisy with the original fans.
Xigmatek Utgard, Fractal Design R3 are also good cases worth considering. The R3 is the new improved model from the R2 and has great cooling while still being considered very quiet (the old one was super quiet but just a little too warm for some people's tastes)
If I had total budget of around £100 I would get a fractal design R3 and a couple of £4 yate loons and a couple of good 140mm fans probable total cost £100.Barring that I'd get the cheaper Coolermaster CM-690 II Advanced Dominator Case, wouldn't go near that Utgard i think although the cooling is adequate it's ugly and basic.
If the R3 is out of stock that is what google is for no law against recommending a case just because it's out of stock here.
So hows about this then:
2 of these 120's for the bottom:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-SY&tool=3
1 140 on one door:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-056-AK
1 80 on the other side:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-SH&groupid=701&catid=57&subcat=819
Takes me slightly over budget (£117 with the case) but I can live with that.
If that looks good I'll order them later. The case and PSU should be turning up today.
As I didn't get a reply before the cut off point for delivery tomorrow I went ahead and ordered them anyway...hopefully they'll do the job.
Case and PSU arrived an installed now. Took me about 2-3 hours to change everything across and do some cable management but I'm happy with it. Only thing I might look at doing is putting some flavour of coloured fan on the top as my case sits on the floor and there seems to be room for another top fan. Something cheap and cheerful, it'll be purely for aesthetics but will make my mind up once the other fans are in there.
Cheers for the help in getting me this far.
