At the moment, our phone line from the box where it enters the house (photo 1) is a crusty paint covered cable that runs from the front door to the kitchen at the rear of the house (photo 2), following the skirting and looping up and over all the door frames. It all looks old.
The previous owners (we only bought the house recently) drilled a hole through the skirtings and wall, and poked a phone extension cable through to the sitting room at the front of the house.
I'd like to permanently move the phone socket in to the sitting room, routing the cable via the basement beneath the sitting room, rather than around the skirtings. From there, I can run some cat5 up to the study. We are currently decorating all the aforementioned rooms, so a good time to make holes or fit sockets.
We've had an electrician in fitting some outside lighting, and he mentioned replacing the cable from the box to the socket with cat5. Is that advisable? Otherwise, am I likely to encounter any problems doing a like for like install, but with the phone socket on the other side of the wall?
Thanks for any input.
