Options for the bottom part of window
14 Apr 2009
Cheshire
This is a view of the side of the case (core x9). I want to cover the bottom of the window.
I could buy 4x120 RGB fans. For looks only, as it's a window with no vents. Or what else?
Could I get a decent decal? Or an RGB panel?
Ideas ?
Why not look for some perforated sheet metal, cut to size, paint black to loosely match the far side of the case. A very quick look around suggests you can get stainless steel sheets 50cm x 20cm with 3mm holes for about £20 on the bay. Other sources will be available with more looking.
edit:
diy-mesh.com
seems to have hexagonal hole metal which would match the white of the case too.
