You just answered your own questionStevenG said:if i get a dual core chip. will u use both cores? i'd need dual core software to use them both.
Jokester said:You're MB is going to limit you if you get a 165.
The Neo2 chipset can only hit 280-290 max - a limit of all nF3 chipsets unfortunately. Mine topped out at about 280mhz when I had it.Sigg said:![]()
I've got a 165 with a Neo2 Platinum & it's fine: stable @ 2.6 and it's only one core of the CPU that's stopping it from going higher...
