Hi all,
I've seen screenies of people getting over 3000Mhz from Opty 146s on air with exactly the same stepping as I have. My temps are fine, well lower than 50deg after a while on Prime95.
I'm getting 2800Mhz on 280FSB with 10x multi, runs stable at 1.4V or 1.45V. Won't go past 286FSB without falling out of Windows so I'm thinking I should up the voltage to 1.5 or even 1.55.
Systool and CPU-Z show my Max VID as 1.45, and if I set it above this, there's no change. Sticks at 1.45. Am I missing a setting somewhere? Changing CPU Voltage in BIOS (ASUS a8n SLI mb) makes no difference. If I set CPU Voltage to 1.5 for example, it will boot with 1.4.
I'm presuming by the way that VID is the same as VCore is the same as CPU Voltage - please tell me if I'm wrong.
So in summary, how can I increase my CPU Voltage to 1.5 or above?
Cheers,
Scott
Cheers,
Scott
