opty 146 question about multiplyers
4 Feb 2003
telford, shropshire
hi,
currently got it running at 320x9 on 1.5v, but cant get it to run 300x10.
running it on a dfi lanparty, is there a particular reason it wont take the 300x10 ?
thx
mp260767 said:
hi,
thx
could be because 320x9= 2880 & 300x10=3000
have your started at say 275x10 and pushed it up 5mhz (fsb/htt) at a time.
yeah sorry the explanation isnt too clear, i know what i want to ask just having trouble finding the right words :(
i realise there is a speed difference, just trying to understand what the multiplyer does that causes the issue.
yeah i did get what you meant.... (well almost)
are you sure the cpu can do 3ghz, most can do 2.8-2.9 easily, but 3ghz is more of a task.
i have had 2x 146's, one wouldnt do 3ghz no matter what but would do 2.9 with less than 1.5v
the other would do 2.9 with really low Vcore (around 1.45) but needed 1.53 for 3ghz
have you tried 290x10?... i have had trouble in the past using low a lower multi at the same fsb, so i guess it could be one of those unexplained things
hope i have got what your meaning :D
