Opty 165 CCBWE 0551WPMW What to expect ?
29 Jul 2005
Warrington
guys,
I have an opurtunity to buy this chip at around £100 but I am not convinced by its potential to reach 2.6GHz (the minimum I would like)
Anyone got this chip ?
What OC did you get ?
Heat and volts ?
Opterons are usually good clockers due to them being server chips. Iv got an opty 170 at 2.7ghz 1.488 volts, the problem is keeping them cool, if you can keep it cool, im sure it will clock high, i know for a fact this chip (170) does 2.8 on water.
Id say go for it and sell your old one, wont cost you -that- much then, and you will have a nice dual core servery chip type thingy :D, i know dual core in windows makes a mahoosive difference for me, and potato shop is just simply awesome
Models:
165 (1.8 GHz)
170 (2.0 GHz)
175 (2.2 GHz)
180 (2.4 GHz)
Stepping Info
CCBWE are less likely to be coldbugged.
CCBBE and CCB1E are very likely to be coldbugged.
Averaging >=2800
CCB1E 0550VPMW
CCB1E 0605XPMW
CCB1E 0608MPMW
CCB1E 0609FPMW/FPAW
CCBBE 0610DPMW (most consistent for 3GHz +)
CCBBE 0615DPMW/EPMW
CCBBE 0617FPMW
CCBWE 0602BPMW
Averaging 2600-2800
CCB1E 0606FPMW
CCB1E 0609FPBW
CCBWE 0530TPMW
CCBWE 0546XPMW/MPMW
CCBWE 0550UPMW/VPMW
Averaging <=2600
CCBWE 0534SPMW
CCBWE 0541RPMW
CCBWE 0543TPMW
CCBWE 0551UMPW/VPMW
CCBWE 0604TPMW
CCBWE 0607UPBW
CCBWE 0609FPAW
Cool, thanks guys,..I might just be joining the x2 club :)
Although I am a little sceptical that I will notice too much of a difference in games, I guess it never hurts to have more raw power available.
As for keeping things cool,..I use a AC Freezer pro for my 144..use same again for Dual Opty or something better ?
I bought an Opteron 165 from OcUK in May, got 2.8Ghz at 1.45v but I ended up running it at 2.6GHz at 1.4v. Never checked the temps, but it didnt crash so that was good enough for me :) Stock heatsink, too.
I've never heard of an Opteron that was a bad clocker...
