I'm having cooling probs with my Opty 165.
Details :-
Opty 165 @ 300*9 (1.375v)
Arctic Cooling Freezer Pro with AS5
120mm rear exhaust fan
2 * Antec SmartCool 92mm front fans - dunno if these are making the noise?
Temps :
Core 0 : 48C (idle)
Core 1 : 45C (idle)
M/B temp : 52C!
Antec Titan case with TruPower 550W PSU - fan speed 952rpm (this seems low?!)
Any suggestions? I also want to try to make the case a bit quieter if poss, but with those temps it's a bit worrying!
Want to get by with this setup until summer when hopefully the new AMD chips will be out and also R600. I can dream!
Details :-
Temps :
Core 0 : 48C (idle)
Core 1 : 45C (idle)
M/B temp : 52C!
This is another aspect of my old antec P180 that i disliked. It had 1 120mm fan drawing air into the case and 2 rear 120mm fans extracting. The volume of dust sucked through the drive bays and into the case was phenominal!!! The joke was that the front 120mm fan had a dust filter on it! I hardly ever had to clean it!!!
