Need some advice please.
First of all, i'm not upgrading to Conroe as it would require too many parts to change.
I want to upgrade my AMD 64 3700 to dual core.
I've got the choice of Opy 175 (2.2Ghz)@ £152 or the Opty 180 (2.4Ghz) @£192, both retail versions. (note: there is no way i can find out their steppings before i buy)
My system system will be:
Choice of the above CPUs
MY-005-GL GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5
DFI LanParty UT RDX200CF-DR Crossfire (Socket 939) Motherboard
GX-053-PC PowerColor ATI Radeon X800 GTO 128MB DDR TV-Out/DVI (PCI-Express)
Arctic Cooling Freezer 64 Pro CPU Cooler
4 Sata HDs
1 IDE HD
550W Generic PSU (i am aware that i might have to upgrade this but would rather not for the time being-it is happily coping with my 3700@2576 at stock volts)
DVDRW
Case with 2X120mm front intake and rear exhaust, 1X80mm top fan
I will be overclocking this CPU.
Which processor should i go for and why?
Thanks
m
4 Sata HDs
1 IDE HD
DVDRW
Thanks
m
