18 Dec 2021 at 22:09 #1 Scougar Scougar Soldato Joined 30 Jan 2007 Posts 15,485 Location PA, USA (Orig UK) I just bought an Oculus Quest 2 and have an RTX 2060 which only has hdmi and display ports on it. What link cable can I get to get this setup to work please?
18 Dec 2021 at 22:27 #2 melmac melmac Soldato Joined 19 Dec 2010 Posts 12,339 You need a USB 3.0 cable, either the Official Link cable from Oculus. Or You can get a cheaper version from Anker or Kiwi design.
18 Dec 2021 at 23:18 #3 Scougar Scougar Soldato OP Joined 30 Jan 2007 Posts 15,485 Location PA, USA (Orig UK) Ok. Picked up a 3.2 cable so should be of sufficient quality.
19 Dec 2021 at 13:56 #4 varkanoid varkanoid Soldato Joined 31 Dec 2007 Posts 13,723 Location The TARDIS, Wakefield, UK Yeah the "link" cable goes in your PC USB port not the graphics card.
19 Dec 2021 at 15:47 #5 Scougar Scougar Soldato OP Joined 30 Jan 2007 Posts 15,485 Location PA, USA (Orig UK) varkanoid said: Yeah the "link" cable goes in your PC USB port not the graphics card. Click to expand... Ah thank you. I had not realized that! Since some GPUs came with usb-c ports, I had assumed it went in that. Thank you team!!!
20 Dec 2021 at 16:55 #6 smilertoo smilertoo Soldato Joined 4 Aug 2005 Posts 3,361 You dont need a link cable, the wifi works well.
