I'm considering going onto the Orange Unlimited Broadband package, but I'm a little wary of the Live Box that comes with it. The advantage of the thing is that I get the free calls (the International free calls are what really interest me, since I'll be going abroad later this year and it'll be an easy way for my parents to keep in touch). The disadvantages are, well, the information that I just can't seem to find anywhere. These are:
- What's the port forwarding like on the Live Box. I'm currently using a router that I can forward as many ports as I want on. I play games, and some of them need hundreds of ports open at a time. I'm hoping that the Live Box can do this as well. Nowhere have I read whether you can even log into the thing to mess with settings, so I'm a little skeptical.
- How good is the wireless network on this thing? I noticed there's only 2 wired ports on the damn thing, and there's 3 PC's in the house. I'll have to put one on wireless, but if it keeps dropping then that's going to be a problem.
The port forwarding is the most important issue for me really. A final thing that crossed my mind was whether it'd actually be possible to use my current router. All the Orange site talks about is sending out this Live Box and how you need to use it, but is there anyway to set the connection up on my current router? If so then I can keep on using it until I go abroad, then connect up the Live Box once I go.
Not sure if anyone can help, but figured if I should try anywhere it should be here. Thanks.
