I know the concenses is it does not mater which order the pump/ Rad / blocks go, but what about the order of the blocks? I have a chip set block, a Mofset block and a CPU block in my loop. I want the CPU to be at its coolest, so does the the CPU block need to be first block in the loop after the rad? Would routing the fluid through the other 2 block before the CPU block result in higher CPU temps?
Cheers
Cheers
