Ordered an xda mini S
28 Nov 2003
Manchester, UK
After actually seeing one in the flesh, I decided this is good enough for me :) It seemed a lot smaller in real life, about the same size as my old 6630 compared to how it looked in the pics.
Anyway iv just won an auction over on the bay, for £260 + £15 special delivery for a brand new unlocked one, il be using my o2 pay as you go with it but afew things I now need...
A good 2GB memory card
A GPS receiver for tomtom sat nav
and anything else you can think off that id need?
Just had a look over at mymemory, but they are out of stock on the 2gb sandisk memory cards, anywhere else that stocks them? Are they good cards, they seem considerably cheaper then some other brands iv seen?
I had one for 2 weeks - v disapointed, at times it wa so slow it took 5-10 mins to get out of a 'crash' it was just quicker to restart the phone which took at least 5 mins. Such a pity as it had real potential. I sold mine on ebay ready for the next gen phones - maybe the new nokias (symbian!) or just a smartphone with a faster CPU..
sweet, grab a 32 channel bluetooth gps reciever off ebay, look on mobymemory for the memory card, apart from that theres nothing else you really need as it comes with a decent case and headphones
Thanks for telling me now :( :p
i'd personally get the m600 instead, has a considerably faster CPU and is a lot thinner.
As for GPS unit, get a holux slim one based on the surfstarIII chipset :)
Tom.
one main thing you need to do when you get it is give it a hard reset, then once its switching on it will says "customising device in 5 seconds" once it says this hit the soft reset button, that way you will get none of the o2 branding on the main screen, which means the xda is more responsive and a bit quicker
Thanks for the tip mate :)
which is better:
SanDisk Mini Secure Digital 2GB Card With Adapter
or
MobyMemory High-Speed 2GB mini-SD Card.
(including SD adapter)
The XDA Mini S is unuseably slow...until you put it into Corporate mode after a hard reset. Doing this doesn't install any of the O2 gubbins and makes it a hell of a lot faster. The only thing is you have to set up all the gprs/mms settings yourself, hardly a major hassle.
If you want a smartphone with a decent keyboard, it's a great phone. I love mine and have since found myself far more organised. :)
