Ordering Parts Tonight.
28 Aug 2010
Hi everyone.
I'll be ordering all the parts for my new rig tonight, and just wanted to make sure I haven't done anything silly (incompatible hardware etc)
Also with an OEM dvd drive, am I right in thinking the sata cables will come with the mobo, or should I pick some of them up as well?
Thanks very much!
spot on, yes the cables come with the motherboard.
change the harddrive to a black, Samsung F3 or Seagate Barracuda 7200.12
That looks good, I think i am probably wrong with this
But if the 2 gtx 460s are both dual slot surely they will be covering both of the pci solts?
So you would not be able to use the wireless adapter you have selected.
And as for the hard drives, the Caviar Blacks and samsung F3's are rather good.
The wireless card uses the X 1 PCI-E SLot at the top :)
New Parts
Personally having spent so much on other components I would at least order 2 of the 500gb Hard drives to go RAID 0 for the extra speed.
I'm only jealous though as i'm still using my old q6600 (although it still a killer after all of this time)
Change the case, the 900 series makes me cry.
Personal preference though, if you like it go for it :)
The rest of the spec looks ace, have fun.
What would recommend changing it to?
Looks aren't overly important to me, just looking for enough room and decent airflow, which the 902 seems to offer.
Sub £100 if you have any suggestions that would be awesome
If you can stretch get one of these
Big, Fugly, but one hell of a cool case :P (I own one :D)
But if the budget is that important keep the 902 or get one of these
The Dark Fleet is apparantly a beast of a case
Better to be safe than sorry for £5. I have some thermal paste lying around but its about 2 years old, not sure how healthy its going to be :)
