Hi All,
If anyone out there knows much about compatibility issues with pcs can you have a look at this rig that im ordering next week and see if you can see any problems i may have with component compatibility. (I am an avid fps gamer).
http://www.andres-funserver.co.uk/demos/oc1.jpg
The questions i am tryng to get answered with that setup are:
1. Will the raptor HDD go with that set up smoothly?
2. With the GFX card it states "slave needed" i thought they could run standalone but only needed a slave if cross fire was enabled, is this correct?
3. PSU is it adequate/siutable?
4. Whats best operating system for this rig?
would appreciate anyones views before i order.
Cheers
Andre
Cheers
Andre
