Does the SAS drives work off std SATA connectors![]()
Which monitor would you suggest? I'm not actually too bothered about the whole TV thing, just want a 26" screen with at least one HDMI connection.Looks good. Why that screen in particular? Why not just buy a TV tuner for your PC and then buy a better screen, i.e. a non TN panel. Also, I would just get the standard P6T not the Palm Edition, which seems to simply come with an external readout display thing...or something.
The Antec 1200 looks good to me - but I guess it is a personal opinion - it has also got pretty good reviews wherever I look.£400 on a hard drive is silly.
also spend the extra £10 and get the zalman psu..
I think the antec 1200 looks cheap/tacky and nasty. You could get the Lian Li PC-A10A Aluminium Full-Tower for £20 more.
Which SATA's would you RAID?Nope, but the motherboard does have SAS connections.
I'd think the cost of the SAS drive is a bit OTT though. I'd be looking at the 940 chip and a SATA RAID.
Any suggestions for the screen?Lose the hard drive and screen and get a wd black 1tb and a decent sammy panel.
I want a quick HDD set up. What would you suggest?
