orginal xbox wheel pc mod???
30 Sep 2011
Over the hills and.......
Any one know how to mod an orginal xbox wheel to work on pc?
Everything I find is to do with the 360 and bearing mod:confused:
The original Xbox had no official wheel so you're unlikely to find any custom drivers like there are for the Microsoft IR receiver and Headset Communicator.
The 360 wheel works with the above dongle, but the force feedback support was never delivered in the drivers as promised.
this adapter with a wired controller
but then there is this
i'm not going to spend 200+ and stuck with using it on the pc, I get my fantec csr poverty spec on tuesday:D just need to hide it from the wife
