This was that last setup
No what I have done is turn the case on its side and fitted it in a 19" rack in my studio.
I have turned the Pump around and the res.
But I'm getting a gargling sound and the water is not going around clearly and at speed. Then after abot 30 mis the water flow goes to normal and the gurgling stops.
When I turn the PC off over night and turn it on again in the morning the gurgling starts and the water isn't running smooth until after 30 mins again.
The rad is now on its side. I thought a Rad could go in any direction?
