OrigenAE S14V HTPC?
30 Dec 2005
Hi guys,
I am thinking of getting a HTPC instead of using my HP Microserver as a Plex server/client. There is 4x4TB hard drives in there but can only see that the OrigenAE S14V can utilise them.
Anyone got this case? My HP is near silent as I have a passive PSU in it and a modded fan which runs around 650rpm iirc.
Love the look of the OrigenAE S14V but are there any other similar which can hold 4 hdds?
Cheers
Have you not considered keeping the Server stashed away somewhere and just having a simply client ; xmbc pc or something with lex to access the files?
Yes, decided to keep the server as is after getting rid of WHS2011 and installing Win8.1 Running a lot better now and boots straight into Plex.
My server has a passive PSU and modded case fan so runs fairly quiet anyway, plus you won't hear it anyway with movies playing.
