Man of Honour
- 17 Feb 2003
- Chelmsford
Quick question.. I take it you can only have two squad companions at one time? What happens to the characters that you don't select as part of your squad? Can you meet up with them later?
ta,
ta,
every way possible.
Right pain in the arse and I can't believe they didn't change this after KOTOR2, I know that logically if person X has been issued a suit of armour, you wouldn't expect person Y to exit the spaceship and then be able to put it on. BUT, it's not like you can't manually get that situation to happen via the method I described above. So they are forcing you to do a laborious task for the sake of continuity, with the same net result as if you could just swipe items of characters who aren't in the party.
