Original xBox to VGA
20 Mar 2006
Hi, wondering if anyone with an old original xbox can help answer a question. Is it possible to connect the console to an LCD flat panel monitor?
What are the outputs on the back of the original xbox? anyone got any experience doing this?
Ideally I would like to do it via a cable only rather than having to add a converter box.
There was a special bit of gubbins made called the X2VGA+ which I bought and definitely works. Whether you can still buy it or not is another matter entirely.
What game(s) are you trying to play? Have you tried them in the 360 (assuming you have one!)
