Orion TV500HD High Definition Ready 50'' Plasma Television
6 Jun 2005
Just got an email from a huge supermarket chain offering:
Description
The Orion TV500HD High Definition Ready 50'' Plasma Television features The 3rd Generation LG panel offering a fantastic 10000:1 contrast ratio and WXGA (1366x768) resolution with High Definition compatibity and a host of great features.
Watch your team asif you were there !
Main features
LG X3 panel.
HD-Ready.
WXGA resolution (1366 x 768).
Brightness: 1000 nit (Panel Spec).
Contrast ratio: 10000 (Panel Spec).
Multi-standard PAL / SECAM tuner.
UHF / VHF compatibility.
Accepts NTSC 3.58 & 4.43 / PAL 60Hz (for AV Input only).
NICAM stereo / A2 dual BBE audio.
Automatic set-up Fastext (812 page memory).
On-screen menu system (English / French / Spanish / German / Italian / Russian).
Aspect ratios (AUTO / 4:3 / FULL SCREEN / 16:9 / CINEMA / 14:9).
DNR feature (Digital Noise Reduction).
Sleep timer (up to 120 minutes).
Auto shut-off.
3 x SCART sockets (2 x RGB / composite 1 x S-Video / composite).
HDMI socket with audio input (for HDMI/DVI use).
Component-in sockets with audio input (RCA).
Side-mounted RCA AV input & S-Video input.
PC input socket (D-Sub) with audio input (mini-jack).
RCA audio output sockets.
Headphone socket.
Audio output 2 x 10W
Net dimensions(without stand):1255 x 125 x 820mm (W x D x H).
Net dimensions (including stand): 1255 x 411 x 869mm (W x D x H).
Net weight (without stand): 38.5kg.
Net weight (including stand): 48.5kg
Measures - H 86.9 (inc stand) / 82 (without stand) W 125.5 x 41.1 (inc. stand) / 12.5 (without stand) CM
Manufacturers Guarantee Period: 1 Years Manufacturers Warranty
Delivery
In stock in our warehouse, normally delivered within 3-7 working days after you have received your order confirmation email.
Order confirmation emails are sent after security checks have been completed which can take up to 48hrs.
I have no idea whether this is any good but the specs are reasonable
Just incase anyone else is interested, I personally am not
edit - Mods I have taken the price out of the original post as I wanted to be sure I wasnt breaking any rules. I hope this is acceptable
