im using:Gigabyte GA-965P-DS3(F5_bios)...Intel Core 2 Duo E6400...arctic freezer 7 pro...2GB Corsair DDR2 XMS2-6400C5 TwinX...7900 GTO...
ive got cpu host freq. to 400, multiplier at 7, (so 2800mhz)
memory multiplier to 2, (ram running at 800mhz @1:1 & 5,5,5,12)
pci express freq to 100
i have also fiddled around with voltage a tiny bit, i raised MCH by +0.1v,
& cpu was running at 1.325v, but i dropped it to 1.312v
now before i changed the voltages when i ran orthos on blend test, it would run for around 5 or 6 mins, then i would get an error , and the caps lock on my keyboard would start turning on and of until i exited orthos...
i checked the text file in the orthos dir. and it said this:
FATAL ERROR: Rounding was 0.5, expected less than 0.4
so i changed voltages, tried again, and same problem, what is it, and what should i do about it?
cheers
jon
(oh, and temps are reasonable, not great tho!)
cheers
jon
