- 18 Feb 2004
- Lincolnshire
when i run orthos i get the following result and yet ive run this earlier in the week for 2 hours with no error -
Type: Large, in-place FFTs - stress some RAM Min: 128 Max: 1024 InPlace: Yes Mem: 8 Time: 15
CPU: 3030MHz FSB: 433MHz [432MHz x 7.0 est.]
12/02/2007 19:25
Launching 2 threads...
Using CPU #0
Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
Test 6, 4000 Lucas-Lehmer iterations of M18874367 using 1024K FFT length.
Test 7, 4000 Lucas-Lehmer iterations of M18474367 using 1024K FFT length.
Test 8, 4000 Lucas-Lehmer iterations of M18274367 using 1024K FFT length.
Test 9, 4000 Lucas-Lehmer iterations of M18274369 using 1024K FFT length.
Test 10, 4000 Lucas-Lehmer iterations of M18074369 using 1024K FFT length.
Self-test 1024K passed!
Test 1, 4500 Lucas-Lehmer iterations of M17432577 using 896K FFT length.
Test 2, 4500 Lucas-Lehmer iterations of M17432575 using 896K FFT length.
Test 3, 4500 Lucas-Lehmer iterations of M17115073 using 896K FFT length.
Test 4, 4500 Lucas-Lehmer iterations of M16815071 using 896K FFT length.
Test 5, 4500 Lucas-Lehmer iterations of M16515073 using 896K FFT length.
Test 6, 4500 Lucas-Lehmer iterations of M16515071 using 896K FFT length.
Test 7, 4500 Lucas-Lehmer iterations of M16297569 using 896K FFT length.
Test 8, 4500 Lucas-Lehmer iterations of M15997567 using 896K FFT length.
Test 9, 4500 Lucas-Lehmer iterations of M15597569 using 896K FFT length.
Test 10, 4500 Lucas-Lehmer iterations of M15597567 using 896K FFT length.
Test 11, 5300 Lucas-Lehmer iterations of M14942209 using 896K FFT length.
Self-test 896K passed!
Test 1, 5300 Lucas-Lehmer iterations of M14942209 using 768K FFT length.
Test 2, 5300 Lucas-Lehmer iterations of M14942207 using 768K FFT length.
Test 3, 5300 Lucas-Lehmer iterations of M14155777 using 768K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 35 minutes 9 seconds - 1 errors, 0 warnings.
Execution halted.
any ideas please ?
12/02/2007 19:25
Using CPU #0
Execution halted.
any ideas please ?
