Hi, im running my E6400 at 3.42Ghz, it seems ok, no crashing etc. but the problem comes in Orthos: It gives me a fatal error after only 14 seconds =/
Im not sure what im doing wrong..
Can someone point me in the right direction?
Cheers,
Jay
ORTHOS said:Type: Small FFTs - stress CPU Min: 8 Max: 64 InPlace: Yes Mem: 8 Time: 15
CPU: 3424MHz FSB: 428MHz [428MHz x 8.0 est.]
20/03/2007 17:49
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
1ress Stop to end this test.
1:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:Beginning a continuous self-test to check your computer.
2ress Stop to end this test.
2:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
1:FATAL ERROR: Rounding was 0.5, expected less than 0.4
1:Hardware failure detected, consult stress.txt file.
1:Torture Test ran 0 minutes 14 seconds - 1 errors, 0 warnings.
1:Execution halted.
2:Torture Test ran 0 minutes 14 seconds - 0 errors, 0 warnings.
2:Execution halted.
Cheers,
Jay
