Having run it for the past 2 hours without it failing, and having S&M fail within the first 5seconds of the level 1 cache test, I wondered if S&M was at fault.
After checking Orthos settings, at default, it only tests up to a maximum of 8k for Small FFT's. Whereas in Prime95 proper, it'll test a lot higher than that.
So Im wondering if Orthos at default is a good test for stability at all. Ive allowed up to a max of 4096k in the custom settings and have just started it off now. Will see how long it goes
Anyone else noticed this?
