orthos query
6 Jul 2006
co durham
put my e6600 in and all i did was up the fsb to 333 which give me a clock of 3.0ghz,everything runs fine so i did a run of orthos and this what happened,first core didnt go past 5 but had no errors were as the second core just kept going and going,any ideas please
Were you doing anything else with the PC at the same time? If a core is running something else then it'll lag behind anyother core that's only running Orthos.
If not then I'm a bit lost, though Blend can be a bit strange if one core ends up using all the RAM and the other one doesn't get enough RAM to run the CPU at full speed.
Jokester
