Orthos reporting 'Execution Haulted'
3 Jul 2006
St. Neots
New build with Vista 64bit
Running Orthos to make sure everything stable but it keeps stopping itself after an hour or so!
It just reports 'Execution Haulted 0 errors 0 faults' or something like that!
Under speed fan the cpu is reporting 56c and the Aux is 59c
Try one stick of ram at a time. I had similar issues when I got my ballistix ram and it turned out that one stick was iffy.
I think I will try up'ing the ram volts to 2.2v as have 4 sticks, instead of the 2.1v, and will try up'ing the MCH volts 1 more notch.
Will do a screenie if it does it again!
What you guys think?
The Geil shouldn't need 2.2v.
The MCH volts are probably more important for it when running 4 sticks.
