Yes
But i'll have a go.
Most peeps seem to think that the GTL's and VTT just allow them to get a higher clock using less Vcore, and to a certain extent that's true. But they come into play much much more, with stability. To give a good example, look at the link in my sig. VTT at 1.17v and GTL's 68-67-69. I can run small fft's in Prime/Orthos all day long with values 3 or 4 either side of those, with no problem. But run large fft's or "blend" and it will fail within 10mins to 25mins. The only GTL values that work at my clock using 1.17v on the VTT are 68-67-69. Another thing that is a big problem with stability with 45nm's (and this applies to dual cores more than quads), is that peeps use much to much VTT in the first place because they are using it for the wrong reason (to get a higher clock with lower Vcore). In fact, and this applies on air as well as phase, the lower the VTT along with properly tuned GTL's, the more stable the clock.
