Orthose shinannigans
Permabanned
22 Jun 2005
Westbury, Wiltshire
I have this strange issue with Orthos.
Apart from a couple of occasions the other night, ORTHOS always fails between 16:57 & 18:37 minutes and seconds when using BLEND setting!
No matter what the overclock is, or the voltage used always the same thing.
What makes it even stranger is that when I use SMALL FFT I have no issue at all, even upto 4.5ghz for well over 4 hours (before I get bored and want to use the PC for something else!)
Now this would suggest some sort of RAM issue I realise. The RAM is Corsair Dominators 2x1GB running below the 1066 it is certified for (running between 940-960)
Day to day stability is fine, as is encoding to 1080p and an hour or so of gaming.
RAM Memtests fine too. :confused:
It would suggest a ram issue at that time during blend. It could also be that your set VTT does not match your GTL settings. Post up a list of all your bios settings, it should be possible to sort out thr problem from that.
