OS have to be on C:?
17 Mar 2011
Spain
Hi All
Need a bit of help. Friends PC would not boot up and he kept getting Corrupt System 32 so we chucked in the Windows disc and did a repair which seemed to go ok. After though we noticed that the drive where the OS is installed is has been given the 'I' drive letter. He cant remember if this was like that prior to the corruption. He only has one hard drive which is split into 2 partitions. I thought that the OS had to have the 'C' drive letter?
This is the current layout of Drives and Devices:
Local Disk (I) - Win XP installed here
Local Disc (J)
Removable Disk (C) - part of his internal card reader
DVD-RAM Drive (D)
Removable Disk (E) - part of his internal card reader
Removable Disk (F) - part of his internal card reader
DVD/CD-RW Drive Drive (G)
Since the repair job he has had one BSOD which happened 24 hours after the repair but nothing since
Appreicate any advice on this drive letter thing
In my experience - it doesn't have to be C, but a lot of things don't work properly when it's not C. (There's a lot of software that assumes that Windows is on C).
I recommend doing whatever it takes to get it back to C.
can't you just go into disk manager in device management and shuffle the letters around to move the removable disk to something like Z or whatever then change the boot partition to C? Assigning drive letters is pretty easy.
This is what i was thinking would be something to try out first.
Yeah thought about that and did a google but a couple of places said that you cant change the letter of the drive where the OS is installed too.
