Agree about bios,i dont think ssds make that difference to bios but they do once windows has got going.
@Pianobasher: You could get 2 (or 1 bigger drive as i think would be cheaper.). In terms of the saves for games,if you can find them could you not use a directory link (not called this but name escapes me at the moment) where it anything that is saved in that folder is actuallg saved in another folder. It was being done with the f1 2010 replay file and im sure someone who can remember will post its correct name.
edit: symbolic link is what ifs called. Would that not sort it out as the file shows up on ssd but is actually stored on another drive e.g. your normal hdd.
