I've been mulling over the prospect of upgrading my Mac with a solid state drive, but there are a couple of things that I'm a little unsure about.
The first is, as I recall, OS X is built to automatically defragment volumes as they're used, but from reading a lot about SSDs, many of them advise never to defrag them, as they don't suffer file fragmentation like conventional hard disk drives.
So, is there a way to disable this auto-defrag function? I'd rather not trash a £400ish bit of equipment through ignorance
The second point is more about my Mac specifically. EFI 1.7 was released recently to address the issues of some more modern Macs running their SATA interface at 1.5Gbps, instead of 3Gbps in previous models.
However, I'm unsure how far back this 'Previous Mac' definition goes, as my MacBook Pro 4,1 shows a 1.5Gbps SATA interface in System Profiler.
Inconveniently, the Apple EFI/SMC Updates Page omits the exact model I have, but the EFI 1.7 Apple issue doesn't list my Mac under 'Affected'. Is my SATA connection supposed to be 1.5Gbps, and does anyone know if this will affect SSD performance radically?
