OS X Lion and active window issues
6 Jan 2004
Halesowen
This is for a colleague and is a strange one.
I am trying to help them with remote connection but upon clicking a preview window it comes to the foreground for a moment before jumping into the background.
This results in me being unable to use the file edit etc menus.
Apparently it happens in other programs as well (Word etc).
I have googled but I can't describe the problem accurately enough and my search has hit a brick wall!
If anyone has any ideas I would appreciate it.
Thanks
Hey dude, I assume if you try it in another user account it doesn't happen there?
Might be worth using a different set of peripherals incase there is a stuck key or keys that are causing the problem...
Failing that, the ol' PMU and PRAM reset are worth a shot as well...just in case.
