Oscillating Gpu Clock/Artifacts Sapphire 7950 Vapor X
13 Oct 2012
Hello guys, the reason i post this thread is that, im having a "problem" at the GPU Clock.
My Graphic Card is Sapphire Vapor-X 7950 OC Boost, i have it at 1100/1375 at 20% Power Control. I only play Tera Online and League of Legends.
I have 13.1 Driver:
- 1st problem is that im having artifacts in Tera Online, not in League.
- 2nd problem is that the Gpu Clock oscillates, http://tinypic.com/view.php?pic=1zw2sl4&s=6 in this pic i have it at stock clock, my gfx has 2 profiles, 1(850 Mhz) and 2(950 Mhz), i have it set to 950Mhz, as u can see goes from 850-950, i play tera at max setting, temp never goes higher than 62º, vram max 64º. If i have it at 1100-1375 it does from 1100Mhz to 950Mhz, just like in the picture.
- I had a fresh Windows install 3 days ago, cause i got a SSD, OCZ Vertex 4 128GB<- extra info.
